Intel unveiled Core i7 (LGA1366) CPU in November 2008, and X58+ICH10R is the only solution that compatible with it.
There are many brands launched X58 motherboards within this few months, and the price is divided into two segments.
One is hi-end product that higher USD $300, the other one is mainstream that below USD $250.
To compare with X48 solution, DFI launched X58 product earlier than before.
DFI unveiled hi-end UT X58 in December 2008, and DK X58 follows it within one month.
The most interest thing is DFI also launched microATX edition X58 which called JR X58-T3H6.
The leader role today is DFI LANParty UT X58-T3eH8, the price is same with other hi-end competitors.
UT is the highest level in LANParty series, I believe the quality & material will be great!
The color box: DFI use totally different design for the new product.
Accessories
A thick user manual, cables, I/O shield, utility DVD, SLI bridge for 3-Way SLI.
The audio daughter card, powered by Realtek ALC 889; the capacitors are Tantalum-cap.
Flame freezer is an unique feature in LANParty UT series, you can install it into I/O shield for balancing the case temperature;
also, you can install it on north bridge. Of course, the best quality thermal paste and installation guide are accompanying it.
Bottom left of board
3 PCIe x16 (Supports x16/ x16/ x4 and x16/ x8/ x8 mode for ATI CrossFireX & NVIDIA 3-way SLI)
1 PCIe x4
2 PCI
Bottom right of board
6 SATA II(with RAID 0/ 1/ 5/ 10 by ICH10R)
2 SATA II(with RAID 0/ 1/ JBOD by JMicron JMB363)
Power/ Reset buttons (Press at the same time for clearing CMOS)
Debug LED
Upper right of board
6 DIMM DDR3, supports 800/ 1066/ 1333/ 1600 (OC) (DFI is conservative in writing specification, ; actually, you can OC DDR3 modules up to 2000MHz)
1 IDE by JMicron JMB363
Upper left of board
8-phase full digital PWM, this is the most unique feature in DFI UT series.
Accessories
1 PCIe x4
2 PCI
Debug LED
Upper left of board
